File I/O handling in ARM ADS 1.2
Meenz
Newbie level 5
Newbie level 5
ads 1.2 input file
I am using the ADSv1.2. and am trying to run a C source code application which involves reading data from a bmp file, processing it and writin it back into a bmp file.
When i compile it and run it using AXD i found that the input file is not being opened. Is it not possible for the debugger to handle file I/O during software simulation?
If not then how and where do i load this input file to the ARMulator memory so that the code is able to access the data
Help needed urgently and some pointers will be deeply appreciated :|
