subbuindia
Member level 5
- Joined
- Dec 13, 2011
- Messages
- 87
- Helped
- 11
- Reputation
- 22
- Reaction score
- 10
- Trophy points
- 1,288
- Location
- Vellalacheruvu(AP), India
- Activity points
- 1,908
You should read some basics before asking questions. Knowing nothing you mAy be confused.
When the junction transistor was invented, the main collector current was controlled by the base CURRENT.
Jiripolivka - are you sure that YOU are familiar with basics ? The question "how is the BJT controlled" was discussed extensively in this and in other forums.
It is clear - from theory and experiment - that the BJT is a voltage-controlled device (despite some contrary assertions, even in some textbooks) .
It is clear - from theory and experiment - that the BJT is a voltage-controlled device (despite some contrary assertions, even in some textbooks).
Both friends above: My first sentence was that before asking questions you should read the basics. You did not, so you are quite confused.
Clear from theory - yes, as described by the Shockley equation and the Ebers-Moll model.
Experiments can be made with voltage as well as current control, I think. In an intuitive analysis of BJT circuits, it's sometimes reasonable to look at a BJT as current gain element, beyond theoretical implications.
It's not clear to me which posts the statement is exactly referring to. At least it sounds a bit patronizing. I suggest to avoid this tone.Both friends above: My first sentence was that before asking questions you should read the basics. You did not, so you are quite confused.
I don't contradict any of the detail considerations. As you know, I agree with the principle classification of BJT as voltage controlled device anyway.
What did I mean with "sometimes"? There's a number of BJT circuits where the base current is forced by a current source so that it's completely or mostly independent of the base-emitter voltage. In this and only in this case, I consider "to look at a BJT as current gain element".
A small current flowing into the base controls a much larger current flowing into the collector."
The transistor is a current-controlled amplifying device: if a small current flows between the base and emitter, it gives rise to a much larger current between collector and emitter.
My view is that if a student thinks transistors are current controlled devices, it's probably best to leave well enough alone, rather than trying to correct them. After all, if their teacher says it's current controlled and their text book (as far as they've read it) says it's current controlled, then if you say otherwise, they either won't believe you or it will just cause confusion. Hopeully in a year or two they will have gained a fuller understanding.
