raiya_23
Member level 4
Can we use fire optic cable for connecting antennas to communication equipment? Why do we use only coaxial cable for connecting an antenna to a transceiver and fibre optic is used only in data communication?
and how do you expect the small received RF current from the antenna to get into the optical fibre ?
or the large Rf signal from a transmitter to get into the optical fibre ?
basically....
you will need a receiver at the antenna to recover the modulation and that will drive a fibre laser diode transmitter at the other end you can recover the modulation out of the fibre and use it as needed.
On the transmit side, you will need a modulator driving a laser diode to send the modulated signal up the fibre to the antenna on the mast.
At the antenna end you will suce that modulation to modulate a transmitter to feed the antenna
see how much of a major effort it would be ?
thats why we use coax or waveguide
light in a fibre ISNT an RF signal
Dave
Optical glass fiber is a waveguide, similar as for radio frequent waveguides. If it had been possible had it been an advantage to have a tuned hollow center and total reflecting walls also for optical fiber if it had been possible to control center diameter. Drilling inner diameter lambda/2 for light waves is however a a bit tricky to do, in a long fiber cable. Low loss optical glass fiber is instead done in two or several more layers of glass (single or multi mode), each layer outwards with increasing refractive index forcing light waves to travel only in center of the the fiber cable, causing as few reflections in the wall(s) as possible.
Even sound waves can be distributed low loss over great distance with a waveguide of right dimension and high refractive index in the walls. Both these parameters say that a fiber with dimensions for light waves is a poor selection, but RF waveguides can have rather low loss also for sound waves.
Sound waves in optical fiber is common but first after that the sound signal have been modulated to a optical frequency. Same rules for RF signals in optical fiber.
Laser as light source/modulator is a special case as it can travels with lower loss without cable if it is good focused and if it not is raining.
Try "www.jackdaniel.rfwise.com, a short tutorial on RF over fiber technology.
