Fibonacci series using while loop
zilch
Member level 2
Member level 2
Hi, I am trying to implement a Fibonacci series using while loop and written in C. Im not quite good in programming so im asking for help to check if there's something wrong in my code because i cant get the output that i want. I just want the output to start with 1, not 0 (the conventional one). For example, ill input 4; the output should be : 1 1 2 3.
//this is my code
#include <stdio.h>
int main()
  int i;
  int n;
  int a=0;
  int b=0;
  int x;
  printf("Input: ");
  scanf("%d", &n);
  while (i<=n)
   if(i==1)
            printf("Output: \n");
            printf("1 ");
   else if(i==2)
            printf("1 ");
   else
            x = a + b;
            a = b;
            b = x;
            i++;
      printf(" %d ", x);
 return 0;
You had not assigned any initial value to variable i.
To solve that, at line 1 replace int i by int i=1
In addition, you are returning the constant value 0.
Shouldn't you return i ?
I tried your suggestions, and i got an output of never ending 1. :???:
I made a wrong assumption, the return intruction above do not output the fibonacci value. I did not make an accurate analysis of your code, but it do not look so simple like the classic algorithm in pseudo code:
[B]function [/B]fib(n)
i = 1
j = 1
[B]for[/B] k=1 [B]to[/B] n [B]do[/B]
     t = i + j
     i = j
     j = t
[B]return[/B] j
The problem is because you are using a while loop instead of a for loop.
You have to explicitly increment i every time through the while loop, in this case you only do that if i is not 1 or 2
Option 1. either add i++ in each if and else if clause (it's missing from both the 1st and 2nd branches)
Option 2. just put the i++ at the start before the if statement and remove it every where else and change the initial value to int i=0.
andre the return is the OS return code saying the program completed without errors (Hmmm, doesn't seem to work ;-))
Hi guys, this problem is solved.The goal here is to make a subroutine (which i forgot to mention earlier :) ) for fibonacci sequence using loop.
#include <stdio.h>
void fibonacci (int n);
int main()
  int n;
  printf("Input: ");
  scanf("%d", &n);
  fibonacci(n);
void fibonacci(int n){
    int i=1, a=0, b=1, x;
    while(i<=n)
        if (i==1){
            x = i;
            i++;
        else{
            x = a + b;
            a = b;
            b = x;
            i++;
        printf(" %d ", x);
