FFT source codes in C language
adyanced
Junior Member level 1
Can anybody share your FFT source code in C or give a relative link?
Thx in advance.
there's a ton of freely available source code, this is one of the
better ones... it has radix 4 and radix 8 which can help if you
do hardware.
the file I attach came from :
(it's small so I attach here)
    V
You can also try FFTW (available in one of sourceforge pages).
It's the one used in matlab.
FaZeng,
search for fxt library under linux. you can find very optimized code of many transforms in it. for example, you have radix 2,4 DIT/DIF FFT, even NTT based FFT...
other transforms: walsh, hadamard, NTT, basic wavelets...
hope it helps
tahiti
Is the Chirp-Z transform included in the fxt library in Linux?
Thanks you all.
sorry, no chirp in fxt lib
tahiti
    V
