Castillovanv
Banned
What are these FETS doing? why didn't they just use normal fixed resistors instead to set the DC offset for the op amps?
They are using FETs as voltage controlled resistors to set the DC offset for op amps, but why?
What is the difference between using a FET as a voltage controlled resistor VS using a normal resistor?
Adjust the voltage on a FET to the SAME value as a fixed normal resistor, what would be the difference?
