Forlinx
Banned
FET-G2LD-C System on Module is a system module with high-performance and ultra-efficient Renesas RZ/G2L processor. The module has a heterogeneous multi-core Cortex-A55 1.2 GHz architecture and is integrated with a Cortex-M33 200 MHz MCU. FET-G2LD-C SoM has a Mali-G31 500 MHz GPU and supports a variety of display interfaces.
It also has rich functional interface resources such as multi-channel UART, Ethernet, CAN-FD, etc., making it applicable to various applications in industries, healthcare, electric power, transportation, and other sectors.
All components of FET-G2LD-C SoM, including CPU, RAM, ROM, resistors, capacitors, inductors, and connectors, are industrial-grade temperatures and can operate in temperatures from -40°C to +85°C.
RZ/G2L also has a life cycle of more than 10 years, and its Linux kernel is supported by CIP for long-term support. FET-G2LD-C SoM is easy to use and highly versatile with rich peripheral interface resources.
The module also has rich multimedia resources to meet the requirements of HMI and image acquisition. The timer resources of FET-G2LD-C SoM are also very complete, including 1-channel 32-bit MTU3, 8-channel 16-bit MTU3, 8-channel 32-bit PWM, and 3-channel watchdog.
Read More: https://www.forlinx.net/product/rz-g2l-som-130.html
