kamaz187
Newbie level 3
fet input amplifier
Hi All,
My application involves converting HV AC into low voltage DC which is then fed into an ADC.
I have built a prototype with an Analog Devices AD820 Op-Amp and the circuit is processing the signal correctly at room temperature. However as the junction temperature rises above ~55Deg C the output signal amplitude starts to decrease rapidly with any further temperature rise. I think that this relationship is exponential.
I have attached both the schematics and scope input-output screen.
Has anybody got any idea as to why it would happen and also how to overcome this problem as I need for the gain to vary by a maximum of 1%-2% across the temperatures of 20-100 DegC? (All resistors used are 0.1% tolerance and +- 15PPM/DegC temperature variation)
Thank you for your help!
Hi All,
