freeman2
Junior Member level 1
heres a oldie revisited...stanley a meyers water fuel cell
Meyer built a water powered buggy, it was based on his vic tansformer that gave a potential difference out but no current enabling him to split water by a different process.
Meyers vic is at its very basic 3 secondarys wired in series driven by a primary, if you go on a electronics forum and explain this can be made to give a full potential difference out while stopping the influx of current they will give you funny looks. No electronics design engineer will be able to build you such a device from meyers patents.
By changeing the wire from copper to iron on meyers vic we get a very different effect.
i have uncovered that iron is unique in that each atom has a magnetic moment, that is each atom has a north and south pole. These atoms, or electron spin which gives this magnetism, can be manipulated by a external field. With this magnetic field each atom can be aligned to face each other north to south poles. They will then be attracted to each other giveing a effect know as electron clustering. In this state the influx of electrons into your circuit will be stopped.
Below is links showing us some basic physics involved, take the time to read the actual articles, you can start to pick out relevent information and piece together what i am saying.
We can see here how external fields affect electron spin.
When a piece of ferromagnetic material is placed into an external magnetic field, two things happen.
The spins in each domain shift so that the magnetic moments of the electrons become more aligned with the direction of the field.
Domains aligned with the field expand and take over regions previously occupied by domains aligned opposite to the field.
source **broken link removed**
this covers permanent magnets but still has relevant information
"Instead, every electron is a tiny magnet due to its inherent magnetism (what we call electron spin).
Furthermore, the alignment of the electron spins makes a hunk of iron (magnetite) into a magnetic lodestone.
All atoms have electrons with electron spin and magnetic fields due to their orbits about the nucleus. But not all material is magnetic like the lodestone (ferromagnetic). If the electron spins of an atom's electrons are aligned oppositely, their magnetic fields cancel. That's what happens with tissue paper, flesh, or other non-ferromagnetic substances.
Each iron atom, on the other hand, has four electrons whose spin magnetism doesn't cancel. They line up. Aligned magnetic fields make matter magnetic.
Iron is a peculiar, remarkable substance. Its aligned-field electrons spontaneously couple and form small long-lasting domains. The spins inside these microscopic domains are almost perfectly aligned. Most domains, though, aren't aligned. In common un-magnetized iron, many domains are randomly oriented"
source USATODAY.com - Magical magnetism, electron 'spin' and easy iron paths
Some materials are unsuitable like copper here it explains why
Since all matter is made up of atoms and all atoms have electrons that are in motion, do all atoms have magnetic fields?
The answer to this question is yes and no. All the electrons do produce a magnetic field as they spin and orbit the nucleus; however, in some atoms, two electrons spinning and orbiting in opposite directions pair up and the net magnetic moment of the atom is zero. Remember that the direction of spin and orbit of the electron determines the direction of the magnetic field. Electron pairing occurs commonly in the atoms of most materials. In the experiment you observed a helium atom showing two electrons spinning and orbiting around the protons and neutrons of the nucleus. The two electrons are paired, meaning that they spin and orbit in opposite directions. Since the magnetic fields produced by the motion of the electrons are in opposite directions, they add up to zero. The overall magnetic field strength of atoms with all paired electrons is zero.
Such a transformer is possible.
