T
treez
We are doing the core loss calculation for a 120W Offline BCM Flyback operating at 120VAC input. Its primary peak current is 4.97A. (as attached) This corresponds to a Bpk of 0.368T. (Switching frequency is approx 20kHz at the max load condition and this input volts)
We can see that Ferroxcube 3C92 material is much superior to the 3C90 material (though 3C90 comes with standard gaps)
The TDG TP4E material is said to be equivalent to 3C92 but actually has greater loss.
Can you confirm that the B value in these graphs refers to the peak B (not Bpkpk) with B as a sinusoid)?
Also, since we are using a flyback, then we can divide Bpk by two and then use that value with these graphs (since flyback does not have sinusoidal B , but rather, unipolar B)
Also, can you confirm roughly the cost difference between 3C90 and 3C92?
Ferroxcume 3C92 Ferrite:
Ferroxcume 3C90 Ferrite:
TDG TP4E ferrite (page 38)
