feed point on GPS antenna
billano786
Super Member
Full Member level 2
Can any one provide calculations for feed point on ceramic substrate used in GPS antennas?
The position of the feedpoint is important as it should present a 50 Ohm impedance.
May it helps
regards
The majority of the PatchAntennas use a probe feed coming from the bottom side. If this is the point you're trying to find to get a good match, this article should help.
