fault model in vlsi testing
vead
Full Member level 5
Full Member level 5
india
I have little doubt
suppose
we have NAND gate = AND gate + not gate
suppose NAND gate have stuck at fault
to determine fault we will apply test vector to nand gate we don't have need to connect any extra fault model we consider that nand gate is faulty
I think I don't need to create fault model with nand gate on chip ?
Hello,
Can you please explain your doubt with more detail? I am confused becasue we dont connect any extra fault model. Stuck at is the fault model. So what do you mean by connect extra fault model?
By the way ATPG tool will understand the logic of NAND gate, so it will apply patterns accordingly.
thanks maulin for reply now I understood what is fault model
can you tell me how does we scan vlsi circuit I mean which tool we need to test vlsi circuit ,
Hello,
It is better if you go through some basic tutorials of DFT and some book for the basics of DFT.
Thanks & Regards,
Maulin Sheth
Hello vead,
We usually do DFT to test the manufactured defects in the design,
DFT Implementation(scan-insertion)->DC compiler(synopsys),RC compiler(cadence),(inputs->Netlist,libraries, Output->scan netlist,STIL).
DFT ATPG(pattern generation)->Tetramax from synopsys and Encounter test from Cadence(Scan netlist,STIL are the inputs and patterns(SAF,TF) are the output)
As Maulin mentioned read some basic tutorial to understand the concepts.
Regards,
yuga
