Fast pwm generation for h-bridge inverter
Odion
Newbie
Newbie level 3
Hello I am a newbie here, can someone give some advice,links, steps on how to generate fast pwm 16khz for low side drives and 50hz for high side drives?
For a quick answer here's a common method to generate SPWM pulses. Each pulse length derives from the sine at a given point on the waveform.
op amp generates sine PWM from 2kHz sawtooth and 50 Hz sine positive portion.png
This creates SPWM for only one transistor during one-half of the AC cycle. Its counterpart transistor ('kitty-corner') conducts during that time. The other two transistors are shut off.
Then transistors exchange roles during the second half of the cycle.
Reactions: Odion
    Odion
An example, single chip, most chip resources still left for other tasks -
Regards, Dana.
Hello!
I'm not sure about what you mean by "fast pwm 16khz for low side drives and 50hz for high side".
Usually you want to generate a PWM with a given frequency and a variable duty.
I would suggest to do it with a microcontroller, because you have PWM-capable timers on most of
the MCUs. Once you get one to work, for example 16 kHz, you can build another slower one if you want.
    omsakthi
It refers to a simplified 2 quadrant inverter pwm scheme that switches asynchronously between transistor and free-wheeling diode instead between two transistors. This kind of inverters can only power resistive load and typically produces waveform distortions when connecting an output filter.
