Hayee
Member level 3
Hi Everyone,
I am using FAN with microcontroller and it is working fine. microcontroller just Turn ON and OFF the FAN at particular conditions. Following is the FAN model and circuit diagram.
In the circuit there is a signal coming from FAN which will be go into the circuit and the output of it goes to microcontroller. This signal tell weather the FAN is ON or OFF. basically this signal is used to check if the FAN is in working condition or not.
I am just wondering can I give the PWM signal to the FAN to vary the speed of FAN. Uptill now FAN is running on its MAX speed. By giving the PWM I can change the speed of the FAN according to the certain conditions.
Thanks
Thanks
