ibwev
Newbie level 5
- Joined
- May 12, 2013
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Shreveport, LA
- Activity points
- 1,361
Depends a bit on what type of fan that is?
... commutation current profile to generate a pulse for each commutation.
I presume it's a BLDC motor with built-in electronics. The BLDC can be used as a synchronous generator, but you need to remove the electronics and connect a winding directly. I don't expect that you get a usable signal at the open supply pins, but may be worth a try. Removing the electronics will however reduce an electrical breaking effect by the BLDC generator load.Does this method only work on fans powered by a motor?
