sun_ray
Advanced Member level 3
Can a path that starts at an input port of the chip and ends at the output port of the chip (I-O path) be fasle path? Please let me know on what reasoning thst I-O path be a false path.
Suppose an I-0 path is such that its input to the chip does not come from a sequential output and the chip output of that path will not go to any sequential element. Is it a false path then? To remind one thing is that when I say I-O path I want to mean that path is a combinational path inside the chip.
Jeevanlife
What constraints are you meaning when you write that generally we constraint such an I-O path?
jeevan life
Your answer does not answer the question asked very directly. Can you please answer my question that was asked. You wrote that constraining is necessary if the input to the combinational path comes from a flop sitting outside the chip and also constraining the output of the pin is necessary if the output goes to a flop. Though you are indirectly trying to answer my question, but it does not directly answer my question and I need a direct answer to the point or question. Can you please answer my question to the point.
Regards
jeevanlife
Can you plese answer the following two questions?
1. How can a combinational path whose input does not come from a register outside the chip and does not go to a register outside the chip needs to be constraint?
2. On what occassion a combinational path whose input does not come from a register outside the chip and does not go to a register outside the chip, not be a false path and requires timing analysis to meet the specified timing?
Regards
