Prototyp_V1.0
Advanced Member level 2
Hi.
When doing measurements of earth resistance using fall of potential method, the normal procedure is to feed all results into an app. This app will generate a curve, based on the measurements and then it will output a reference distance in meters and also an estimated resistance for that particular distance, and it's supposed to also be actually measured at the reference distance (the measured results are normally very close to the estimated).
This is all good. But the problem is : Is it possible to manually calculate the reference distance, either by hand or by using a spread sheet ?
I have being reading on Megger web site (that is the instrument my company uses) but none of the online lectures does explain this in depth.
I have taken the time of making a PDF where I have two actual measurements. Then I've put onto some txt and arrows to explain.
