Gaber Mohamed Boraey
Full Member level 3
Hello everyone
I’m working daily on repair electronic boards, mainly UPS machines within different capacities
Most of the problems I see , is blown mosfet, Or IGBT or high voltage doide
When I purchase from local market, the complements for replace, sometimes they are fake, like few weeks ago, I’ve checked mosfet jcs3205 and when I test before install, it gives strange readings, although it’s new and never soldered before
One time before also, over install mosfets and the machine worked fine and everything ok, but when there a load these replaced components damage again, and only solved this by replacing different components from similar board, “ not from supplier but from trusted stock “
Is there any way to check if the components fake or real?, have you met anything like this while you’re repairing electronics?
Please lemme know
Please lemme know
