T
treez
From the below link, it appears that when an alu elec cap fails due to electrolyte drying out…it fails open circuit, which is in some ways harmless…..and so what we can do, is simply put a few solid polymer capacitors in with the capacitor bank, so that when the alu elec's fail open, then the solid polymer ones will be there to give some support….do you agree?
We don’t want to use all solid poly ones, as they are far more expensive.
https://www.illinoiscapacitor.com/pdf/Papers/failure_modes_aluminum_electrolytic.pdf
