Failure Analysis on gate-oxide trapped charge in MOSFET
scottieman
Full Member level 2
Full Member level 2
On Top of Silicon
A N-channel MOSFET is characterized, and is found the threshold voltage is smaller than the specification.
Then the N-channel MOSFET is baked at 150C for 12hr. After that, the threshold voltage of that N-channel MOSFET is within the specification!!!!!
From the above result, I suspect that positive charge are being trapped at the gate-oxide initially. After the baking, the positive charge are eliminated in some way.
The question I have is: This positive trapped charge should be HOLE or Mobile ion (e.g. sodium, Potassium).
Thanks
Scottie
