morzh
Newbie
Hi.
I have a 85-270V In / 14V out Flyback SMPS.
We are failing EFT (Fast transient) test with 1000V applied. We pass 500V one.
The surge is failed in the way that the equipment connected to it (an optical modem) sustains Bit Errors.
I am not sure yet how they apply the transient - we do not have the Protection GND connected: it is a 2-wire in (Line/Neutral) supply, so when they say the transient applied to each line, and then to both lines, I have yet to see it done (will see it tomorrow).
The input is protected by these in following order:
620V MOV (I think about 50 Joules absorption), then 5 Ohms NTC, then 0.68uF cap, 15mH CM choke, and tehn all connects to the rec. bridge.
Extra details:
The Y-cap is 2.2nF and connected between output GND and negative of the rect. bridge Cap (56uF, 400V electrolytic).
The transformer has no internal EMI shielding.
Any ideas? I am going to try different MOV tomorrow, including one for 470V I have handy.
Regards.
Extra details:
Regards.
