I would like to ask, what are the things that i need to consider for simple current mirror.
I know that the output current of the current mirror is linked to the emitter area of the transitors and the avalanche voltage, VA.
What other factors that i need to look upon for this current mirror?
An ideal current source is simplay a current source with an infinite shunt resistor.
So, the higher the output impedance of you mirror the less it will be susceptible to load variations. Generally, a current mirror can drive a low impedance node with no problems. Having a high output resistance means you can drive higher impedance nodes with the current source or, alternatively, you have a high quality current source
You can try for a better performance using cascoded transistors. It will give you a better matching between the 2 currents (you have a much higher output resistance)
