dipk11
Junior Member level 2
Please help me!!
I have a huge report file with some data where i have to do some data processing on lines starting with the code "MLT-TRR" For now i have extracted all the lines in my script that start with that code and placed them in a separate file. The new file looks like this- Rules.txt.
For each of these lines i have to extract the data that lies after "[Folder: 'Picture" If there is no data after "[Folder: 'Picture" as in the case of my first line, then skip that line and move on to the next line. I also want to extract the file names for each of those lines- top.txt, tree.txt
I couldnt think of a simpler method to do this as this involves a loop and gets messier. Is there any way out i can do this? extracting just the file paths and the ending data of each line.
MLT-TRR Warning C:\Users\Di\Pictures\SavedPictures\top.png 63 10 Port is not registered [Folder: 'Picture']
MLT-TRR Warning C:\Users\Di\Pictures\SavedPictures\tree.png 315 10 Port is not registered [Folder: 'Picture.first_inst']
MLT-TRR Warning C:\Users\Di\Pictures\SavedPictures\top.png 315 10 Port is not registered [Folder: 'Picture.second_inst']
MLT-TRR Warning C:\Users\Di\Pictures\SavedPictures\tree.png 317 10 Port is not registered [Folder: 'Picture.third_inst']
MLT-TRR Warning C:\Users\Di\Pictures\SavedPictures\top.png 317 10 Port is not registered [Folder: 'Picture.fourth_inst']
import os
import sys
from os import path
import numpy as np
folder_path = os.path.dirname(os.path.abspath(__file__))
inFile1 = 'Rules.txt'
inFile2 = 'TopRules.txt'
def open_file(filename):
try:
with open(filename,'r') as f:
targets = [line for line in f if "MLT-TRR" in line]
print targets
f.close()
with open(inFile1, "w") as f2:
for line in targets:
f2.write(line + "\n")
f2.close()
except Exception,e:
print str(e)
exit(1)
if __name__ == '__main__':
name = sys.argv[1]
filename = sys.argv[1]
open_file(filename)
