Extra output pins in EPP mode
jandelf
Newbie level 1
Newbie level 1
hi all
i m using the parallel port ( EPP mode ). i have only 8 data pins but i need extra 3 output pins . What i understood is that the control port pins naddressstrobe, nwrite, Reset & ndatastrobe are used for EPP handshaking so i can't use them as extra output pins is that right ? if it is then how can i have extra pins
Re: EPP output pins
Parallel Port Complete should have the answers you need.
