External clock .. is external, internal is internal.why do they differentiate between external and internal clock signals if both the oscillators are inside
So, for example, the oscillator LSE OSC is used just to stabilize the incoming waveform?External clock .. is external, internal is internal.
It´s not where the inverter/amplifier sits, it depends where the frequency determining part is.
External clock: XTAL = externally connected. XTAL is the device that determines the clock frequency .. accuracy and stability.
Klaus
No.So, for example, the oscillator LSE OSC is used just to stabilize the incoming waveform?
THANK YOU SO MUCHHi,
No.
An oscillator consists of an amplifier and a frequency dependent feedback.
An XTAL does not oscillate without an amplifier.
The amplifier is built inside, the frequency determining feedback (XTAL) is built outside.
The amplifier alone does not determine the frequency. The frequency is determined by the external component: XTAL
Klaus
