garg29
Advanced Member level 1
dear friends
i am trying to design a rpm meter using 8051.i am using two interrupts one is the external interrupt (pin 3.3) for the external pulse and another is the timer interrupt for timer to start counting the pulses. now suppose external interrupt routine is going on ,then timer interrupt occurs and starts its routine and before this routine ends up the external interrupt occurs again , then the rpm generates error in count . in IP i have given external interrupt highest priority .and if the case is visa versa then also error generates.
in either of the cases one or other interrupt is missed.
what should i do
please help
with regards
amit
what should i do
please help
with regards
amit
