SherpaDoug
Full Member level 2
- Joined
- Jun 21, 2011
- Messages
- 149
- Helped
- 28
- Reputation
- 56
- Reaction score
- 28
- Trophy points
- 1,308
- Location
- Cape Cod, USA
- Activity points
- 2,260
The Arduino Yun controller board has a WiFi transceiver with a SWF type connector (https://www.digikey.com/us/en/ph/Murata/SWF_Connector.html) which passes through to a ceramic built in omni antenna. Conventional WiFi antennas usually have a RP-SMA or a UFL connector.
What is the best way to connect an conventional external antenna to the Yun? The microprocessor guys on the discussion forums are clearly fish out of water here. Many users need an external antenna because they need to put the Yun board in a metal box. I need a directional antenna to connect to a WiFi hotspot 1/2 mile away.
Lacking any better idea I will probably unsolder or grind away the SWF connector and try to solder the coax from a UFL cable to the SWF pads.
