thylacine1975
Full Member level 6
- Joined
- Dec 7, 2010
- Messages
- 337
- Helped
- 227
- Reputation
- 448
- Reaction score
- 214
- Trophy points
- 1,323
- Location
- Canberra, Australia
- Activity points
- 5,166
Simple inrush protection will give you the most relay-protection-per-[currency unit]-spent.
Just put something like this (https://au.element14.com/epcos/b573...4472?in_merch=true&MER=MER-L53-L5IB-PD-ALT-ST) NTC thermistor in series with your switched load and your problems should go away. NTC Thermistor surge protectors work by offering a (relatively) high series resistance with the load on initial switch-on. Continued current flow after switch-on causes them to heat (due to I2R losses in their intrinsic resistance) which causes their resistance to drop (NTC = *negative* temperature coefficient, i.e. *less* resistance with more heat), thereby allowing the load to draw full power after a 'gentler' turn on.
The only thing to beware is that they can get *hot* - beyond 100C - depending on the load current, so don't put them against a plastic case. NTC thermistors come in a myriad of shapes, sizes, ratings and (generally low) costs so hunt around to find one that works best for you.
