GuyManDude
Newbie
I have an HDMI switching unit that has a momentary push button to switch between 2 inputs and an output. I want to use it inside an arcade cabinet but I want to extend the button to the cabinet exterior so it can easily be switched. I have attached some pictures of the unit. If you would be kind enough to offer some guidance I would appreciate help figuring out how to go about it please.
It has a 4 pin button. Could I solder 4 long wires to the 4 connection points on the bottom of the circuit board under the switch? Most momentary buttons only have 2 conductors though, so I'm confused as to what button I should use. I would like to use a stylish led button like those in the pic if possible.
Thanks for your time and suggestions.
