EXT INT 4Digit Counter using 7Seg in 8051
s.k.sahoo
Junior Member level 1
Hi Masters,
I have written a code for 4 digit 7Seg display counter. There is some error in my code, when i simulate in Proteus 4th, 3rd and 2nd display is not showing Zero (0). Please help.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit clear = P3^4;
uchar code DSY_CODE[]=
    0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff
uchar code Scan_BITs[]=
    0x20,0x10,0x08,0x04,0x02,0x01
uchar data Buffer_Counts[]={0,0,0,0,0,0};
uint Count=0;
void DelayMS(uint x)
    uchar t;
    while(x--)
        for(t=0;t<120;t++);
void Show_Counts()
    uint i;
    Buffer_Counts[3] = Count / 1000;
    Buffer_Counts[2] = Count % 1000 / 100;
    Buffer_Counts[1] = Count % 100 / 10;
    Buffer_Counts[0] = Count % 10;
    if(Buffer_Counts[3]==0)
        Buffer_Counts[3] = 0x0a;
        if(Buffer_Counts[2]==0)
            Buffer_Counts[2]=0x0a;
        if(Buffer_Counts[1]==0)
            Buffer_Counts[1]=0x0a;
    for(i=0;i<4;i++)
        P2 = Scan_BITs[i];
        P1 = DSY_CODE[Buffer_Counts[i]];
        DelayMS(1);
void main()
    IT0 = 1;
    IE  = 0x81;
    while(1)
        if(clear == 0) Count = 0;
        Show_Counts();
void EX_INT0() interrupt 0
    Count++;
  • INT0 interrupt counting_2.rar
try this
 #include <reg52.h>
sbit clear = P3^4;
uint Count=0;
    uchar t;
    while(x--)
        for(t=0;t<120;t++);
void Show_Counts()
    uint i;
    for(i=0;i<4;i++)
        P2 = Scan_BITs[i];
if(Buffer_Counts[i]==0)
P1=0xC0;
else
        DelayMS(1);
void main()
    IT0 = 1;
    IE  = 0x81;
    while(1)
        Show_Counts();
    Count++;
Thanks Mr Arun_9998.
I have alredy corrected the same, and it is working fine.
Thanks
with best regards
sks
