Exporting data from Cadence to MATLAB
Sadegh.j
Advanced Member level 3
Hi all
I am writing a report, and I want to export the simulation data from cadence to MATLAB, and plot the data in MATLAB, since I will have more options for plotting in MATLAB.
How can I do this?
Thanks all
the simplest way is to use the printvs button in the calculator. A more effective way would be to write an ocean script.
Do you have a manual for that?
A manual for what?
Printvs is a standard button in the calculator so you already have the manual.
do your simulation of software gives you a data file e.g. DAT extension file type ???, if yes then you can read that that file in matlab and do what ever what to do with your data.
JoannesPaulus: Thanks, not for the button, for the ocean script bit, what is the differencve between writing the script and simply pressing the button?
versatility. You can customize the script to do some extra processing.
