estradasphere
Member level 4
Could somebody explain me clearly how to export an inductor layout from Momentum to Cadence Virtuoso? I generated a gds2 file in Momentum and tried to import it in Cadence.
After importing the file, the Cadence reports that the import was successful. However, I can't see the inductor (actually nothing) when I open the layout. I suppose that my layer definition in Momentum and Cadence is not identical and may cause this problem. Any suggestions?
thanks in advance
thanks in advance
