DanTheMan
Member level 5
hfss gerber
I've made some 3D designs in HFSS and now want to export them for PCB fabrication. What I had done in the past was to use HFSS -> SAT export -> AutoCad import of SAT -> DXF export -> ADS/Momentum DXF import -> Gerber export
However, this doesn't work very well with what designs I have (the DXFs don't have gaps in the ground planes like they are in HFSS) and other small issues.
Does anybody have recommendations on a better way? Ideally I'd like to be able to manipulate the designs in something like Momentum (putting a few PCBs together on a larger sheet, etc.) before exporting the final result.
Thanks in advance!
Thanks in advance!
