Explanation required for Code
adnan012
Advanced Member level 1
What this piece of code is doing?
typedef enum {
 st_idle = 0,
 st_init = 1,
 st_run  = 2,
 st_rst  = 3,
}state_t;
typedef enum {
 ev_none        = 0,
 ev_any         = 1,
 ev_key_pressed = 2,
 ev_cmd         = 3,
 ev_time_out    = 4,
}event_t;
typedef struct {
 state_t current_event;
 event_t event;
 state_t next_state;
}stateTranMatrix;
static stateTranMatrix st_Matrix[] = {
    {st_idle , ev_none , st_init},
    {st_init , ev_none , st_idle},
Regards!
[moderator action: added CODE tags]
Hello!
This piece of code is not doing much. It just defines enumerations (typedef enum),
defines a structure and a matrix. That's about it. Without seeing the rest of the code,
it's hard to predict what it will actually do.
Dora.
According to blog the author provides a working example at github. Why don't you simply run it?
Blog chapter 10 discusses how to call the state machine.
