Explanation of what is the linked list
yanne
linked list
can someone explain to me what linked list is,, does anyone have source code which uses linked list???hope you can help me,, :?:
Re: linked list
Look for example here:
best regards
Re: linked list
linked list is a linked data structure. AFAIK, most of the time the list is implemented in C or C++ and linked together using a pointer within the data structure (i.e. pointer within the member of the linked list). Usually, "new member" of the list is allocated dynamically in memory using heap allocation function, such as malloc.
Below is an example of singly linked list in C language :
typedef struct s_LIST_MEMBER
int value;
struct s_LIST_MEMBER * p_next_member; /* this is the pointer to next linked-list member */
}LIST_MEMBER;
LIST_MEMBER * p_first_member = (LIST_MEMBER*) malloc(sizeof(LIST_MEMBER));
 * Now begin to fill the list
p_first_member->value = 20;
p_first_member->p_next_member = (LIST_MEMBER*) malloc(sizeof(LIST_MEMBER));
 * Now we have two member, the first member and the second member
 * which is pointed to by the    first member's p_next_members
 * variable.
Look for a software engineering or Data Structure book on C/C++ such as Djikstra's book on software engineering for more explanation on it. Also, a lot books for C/C++ language explain about it :wink:.
Re: linked list
Hi Yanne,
This is example of link list that You want.
if You have problem with it, please feeling free to PM me.
I was tried, and I never get problem.
Siswanto
