A.Anand Srinivasan said:ground bounce is the term used to refer to the change in the voltage of the ground plane from 0V to some value due to inductance in the line connected to the ground...
here due to sudden change in current flowing towards the ground plane through the inductance a voltage is developed.... high frequency noise generally poses a serious problem...
Manjunatha_hv said:Hello Brittoo,
these two documents answers all your queries....
Ground Bounce
Understanding and Minimizing Ground Bounce
http://www.fairchildsemi.com/an/AN/AN-640.pdf
---manju---
A.Anand Srinivasan said:it is profound in circuits where a sudden change in current flowing to ground is possible... it is not necessarily profound in rf circuits....
the inductance along the line is the serious issue... sometimes the capacitance of the ground plane stores charge causing ground bounce... in this case it can be reduced by spreading the ground plane larger reducing the capacitance...
