Explanation of some simple circuit
vojke
Junior Member level 1
Belgrade, Serbia
Hi to everybody! I know that this is a simple circuit but I don't have much knowledge with op-amps. Could someone explain me the potential use and difference between these two circuits. Thanks!
The first circuit uses complementary emitter followers as a buffer/driver. It will have significant crossover distortion. The second circuit includes the transistors in the feedback loop to try to eliminate the distortions due to the the transistor output stage.
Keith.
Reactions: vojke
    vojke
As keith has mentioned, both circuits use Class AB emitter followers as a driver.
The difference is that the output for the 2nd circuit is not in the feedback loop and hence will not be regulated.
This means that your "4.7V" will drift with process, temperature, load, supply etc.
Only "5.4V" node will be regulated at 3*Vin.
If you have studied control theory, the 1st is an example of closed loop control, while the latter is an example of open loop control.
Reactions: vojke
    vojke
