explanation of how to translate C code into verilog
keikaku
Newbie
Newbie level 3
I am brand new to Verilog. I am taking a course. If I am in the wrong place, please let me know.
I am trying to understand how to translate the following C code into Verilog. I just do not get how. Any help is appreciated.
x = 0;
for (i=0; i < 3; i++ ){
x = 2x + 1;
Any explanation of how to this can be done ? I suppose this is simple code, but Verilog seems difficult.
That should be trivial, a simple internet search will give you the results, you can do that on your own!
The bigger question, do you want to compute the value of x (which I am assuming would be of type reg), on every rising edge of the clock or you want to have the computation under 1 clock cycle?
Formally, the code can be converted to verilog by replacing { } with begin end.
An iteration loop in Verilog describes however parallel logic, respectively it will be calculated at once. Otherwise you have to design a clocked sequence (finite state machine).
As the given code has constant parameters, it will be reduced by Verilog synthesis tool to a constant assignment x = 7.
while it is possible to translate C into verilog ... I still recommend to remind that
* C is a software language, where line after line is processed
* Verilog is a hardware description language, where all lines are processed in parallel
Thus C and Verilog have rather different timing output.
In C variables are updated line after line. The variable values are valid (at least for a short amount of time) until they become overwritten by another line .. some time later.
In Verilog this is different, because a variable value (result of a code line) may not be valid (not for a tiny moment), because it may be over ruled by a different line of code.
Verilog: Think as hardware. Don´t think as software at all.
Klaus
you are right, it should be "trivial." but if i knew how to do it i would not be asking this question here. while i do see there are conversion sites, they do not explain the process.
thanks for the response. i have been attempting to use the EDA Playground site to run the code using the "begin" and "end". i am not understanding what could be the issue. i attached a screenshot.
I'm not familiar with Eda playground, but your code is incomplete, it misses module header and end, also variable declaration.
thanks for the response. i added the header and the endmodule in addition to declaring the input. i am getting a different type of error now. i attached a screenshot.
You still did not answer the fundamental question on the number of clock cycles, which is important to determine the final Verilog code!
Hence I did not give out the solution. Nevertheless we keep this for the future!
You have shown us an EDA playground screenshot with just 3 lines of code and nothing more..............
For this I conclude that first of all you need to use a good Verilog book or a good online tutorial, learn at least the basics and then come back here.
LaTeX Commands Quick-Menu:
