Explanation of a C code: pp, &sPID, memset
wakaka
Full Member level 4
Full Member level 4
#include <string.h>
#include <stdio.h>
PID Function
The PID function is used in mainly
control applications. PIDCalc performs one iteration of the PID
algorithm.
While the PID function works, main is just a dummy program showing
a typical usage.
typedef struct PID {
double SetPoint; // Desired Value
double Proportion; // Proportional Const
double Integral; // Integral Const
double Derivative; // Derivative Const
double LastError; // Error[-1]
double PrevError; // Error[-2]
double SumError; // Sums of Errors
} PID;
PID
double PIDCalc( PID *pp, double NextPoint )
double dError,
Error;
Error = pp->SetPoint - NextPoint;
pp->SumError += Error;
dError = pp->LastError - pp->PrevError;
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error
+ pp->Integral * pp->SumError
+ pp->Derivative * dError
Initialize PID Structure
void PIDInit (PID *pp)
memset ( pp,0,sizeof(PID));
Main Program
double sensor (void) // Dummy Sensor Function
return 100.0;
void actuator(double rDelta) // Dummy Actuator Function
void main(void)
PID sPID; // PID Control Structure
double rOut; // PID Response (Output)
double rIn; // PID Feedback (Input)
PIDInit ( &sPID ); // Initialize Structure
sPID.Proportion = 0.5; // Set PID Coefficients
sPID.Integral = 0.5;
sPID.Derivative = 0.0;
sPID.SetPoint = 100.0; // Set PID Setpoint
for (;;) { // Mock Up of PID Processing
rIn = sensor (); // Read Input
rOut = PIDCalc ( &sPID,rIn ); // Perform PID Interation
actuator ( rOut ); // Effect Needed Changes
I not quite understand in some parts this code, can some explain on it??
1.
double dError,
Error;
What is the pp?? *pp?
2.
What is memset?
3.
void main(void)
PIDInit ( &sPID ), wat is &sPID ??
sPID.Proportion , the '.' means????
if possible do explain the whole thing, thanx......
avr221 code
PID is a structure (a way to pack variables and give them a name), *pp means that when calling the function, you pass the adress of the structure, not the data.
It is used because pp will be modified.
2.
What is memset?
memset sets 'sizeof(PID)' (3rd arg) 0 (2nd arg) in the memory located a pp (1st arg).
It is used to initalized everything to 0
3.
void main(void)
&sPID is the adress (in memory) of the sPID
the pid structure is, as I already wrote it, a way to pack some variables. To access to a variable you specify it by .'its name'
It will take too much time !
You should read a book about C langage (and maybe also PID controller ?)
vince
pid.setpoint
The (&sPID) may mean the sPID is passed to the function by reference or address.The changes are effected permanently because the operations are through "&"operator.
The "spid.proportion" means proportion is the member of the structure "spid".
pidcalc
question 1 is closely related to pid theory. As a practical introduction, study this application note from atmel - it will answer your current question regarding PID output value calculation (meaning of question 1):
