pdengineer
Newbie level 3
I am newly learning pd using synopsys ICC flow, pls help me in understanding more about following questions
While doing the block level floor plan,
1 How we decide the size and shape of the block.which factors we have to consider to decide the size and shape of the block
2 reading the IO constraints using the "read_io_constraints<tdf file>", which factors have to consider for initial location of pin constraints,like by side, order, offset
3 i may use "creat_fp_placement" command to place and macros and std cells and then pin assignmets, here how can i assure macros and std cells are placed properly
i have ICC user guide, but do not have document which explains about the concepts.
if any body have docs explains concepts in floorplaing and power planing, pls send to me
