Explaining a byte display code in Visual C++
Help
Advanced Member level 2
Hai..
Anyone help me to explain this program......
#include <stdio.h>
void Display_Byte(const unsigned char);
int main()
unsigned int y = 0x0a0b;
printf("%-35s","Display MS byte of unsigned int y");
Display_Byte((unsigned char)(y>>8 ));
printf("%-35s","Display LS byte of unsigned int y");
Display_Byte((unsigned char)(y & 0xff));
return 0;
void Display_Byte(const unsigned char CH)
unsigned char i, c = CH;
unsigned char Mask = 1<<7;
for(i=1; i<=8; i++)
putchar(c & Mask ? '1' : '0');
c<<=1;
putchar('\n');
/* OUTPUT...
Display MS byte of unsigned int y 00001010
Display LS byte of unsigned int y 00001011
Thanks.........
Re: Visual C++
Hum seems like a code with a function to display bytes in binary (1's and 0's), this funtion is called Display_Byte. So as you can see the input data is the 16-bit HEX word y=0x0a0b, then first the program displays the MS Byte (Most significant byte) of the 16 bit word, that is the byte 0x0a, that in binary it means 00001010, and after that, the program displays the LS byte (less significant byte) that is 0x0b that in binary it means 00001011, as you canb see in the output.
Hope this explanation help you.
Re: Visual C++
this program is to display most siginificant bits and most siginificant bits of an integer value, as follows ;;;
#include <stdio.h> /*including standrad input output liberary/*
void Display_Byte(const unsigned char); /*function to print bite*/
int main() /*main function of the program*/
unsigned int y = 0x0a0b; /*preselected integer number you may change it*/
printf("%-35s","Display MS byte of unsigned int y"); /*just printing that message /*
Display_Byte((unsigned char)(y>>8 )); /*shift y by 8 bits then we send 0x0a the most significant byte of the integer number*/
printf("%-35s","Display LS byte of unsigned int y"); /*printing masg*/
Display_Byte((unsigned char)(y & 0xff)); /*send 0x0b to the lest significant byte*/
return 0;
unsigned char Mask = 1<<7; /*that means 1 shift by 7 bits then we get binary 1000 0000 or hex 0x80*/
for(i=1; i<=8; i++) /* loop to print bit by bit*/
putchar(c & Mask ? '1' : '0'); /*if c contains 1 in position 8 print 1 else if print 0*/
c<<=1; /*shift c by ony bit to left in order to print next bit*/
putchar('\n');
/* OUTPUT...
Re: Visual C++
Hai....
Can you explain 1 by 1........sory... because i really not understand....
#include <stdio.h>
void Display_Byte(const unsigned char); // 1) why use const unsigned char
int main()
printf("%-35s","Display MS byte of unsigned int y"); //2) what's the meaning for %-35s
Display_Byte((unsigned char)(y>>8 )); // 3) How the function work
Display_Byte((unsigned char)(y & 0xff)); // 4) How the function work
return 0;
unsigned char i, c = CH;// 5) why use unsigned char
for(i=1; i<=8; i++)
putchar(c & Mask ? '1' : '0'); // 6) What is the for loop doing??
c<<=1; // How it work and what does it do ??
putchar('\n'); // 7) what is putchar();
Try your best.... i hope you can help me.....
Thank you...
Added after 35 minutes:
return 0;
putchar('\n');
/* OUTPUT...
Hai....
Why use unsigned, why not just use int??
How the message print out, why the binary behind the message ???
How the program know is the most significant byte
i still cannot understand....
Still cannot understand...., what's the purpose for this function....
why some time use unsigned char some time use unsigned int?? Do you know how to write the program for refer the result after compile..
what is putchar do?? Hi...... i also don't how to ask for this... DIFFICULT TO UNDERSTANDS....
Thank you..
Re: Visual C++
Two requests, please:
1. You are asking very basic questions about C syntax. Please get yourself a good C book. I recommend "The C Programming Language", second edition, by Kernighan and Ritchie. You may learn that your example program is doing several unnecessary things!
2. Use the "code" button so everyone can see the indenting.
#include <stdio.h>
int main()
  printf("%-35s", "Display MS byte of unsigned int y");
  Display_Byte((unsigned char)(y >> 8));
  printf("%-35s", "Display LS byte of unsigned int y");
  return 0;
  unsigned char Mask = 1 << 7;
  for(i=1; i<=8; i++)
    c <<= 1;
  putchar('\n');
Re: Visual C++
#include <stdio.h>
//constant or not it will make no difference in such case
int main()
//number of charcaters of the msg is 33 charcaters, so program leave 35 spaces to the left of the screen (-35) and print the string (%s) in 35 spaces to the left
so to additional blamk spaces is left before printing binary numbers
// unsigned char used to convert the posted argument Y from unsigned int to unisgned char
// y=0x0b0a ;now; y>> 8 ;means; 0x000b
// y=0x0b0a ;now; y&0xff (normal logical and) ;means; 0x000a
0&1=0
1&1=1
return 0;
//to avoid any minus in results
for(i=1; i<=8; i++)
// to print bit by bit as charcater contains 8 bits we need loop of 8 turns to print them
c<<=1;
//that means c=c<<1; shift left by one bit then but it back to c
putchar('\n');
// it's a function to print single charcater '\n' means new line
to avoid any minus sign
i answered that before
simply we shift the integer by 8 bits right so the left is the most significant byte
i answered it before
char is one byte, 8 bits
iteger is two bytes, 16 bits
i agree with you its difficult you may replace it by
if((c&Mask)==1) putchar('1');
else if((c&Mask)==0)putchar('0');
Thank you..
    Help
Re: Visual C++
Hai...
1) Please explain this symbol in C:
for(i=1; i<=8; i++)
putchar(c & Mask ? '1' : '0'); // what function for this ? and :
c<<=1;
putchar('\n');
2) Izit the CH carry 1bye=8bit one time to this function "void Display_Byte(const unsigned char CH)"??
3) Now i have the idea what the function doing but how can i going to modified the program for me to easy understand because i still don't how it run...
for(i=1; i<=8; i++)
if((c&Mask)==1) putchar('1'); // not work
c<<=1;
putchar('\n');
Visual C++
That is both broken and clumsy. Mask equals 128, so (c&Mask)==1 is always false.
That is correct and concise.
C students are often puzzled by the conditional expression ? : because many other languages don't have it. It is very common in C programs, so learn it and make it your friend! See section 2.11 of K&R:
expr1 ? expr2 : expr3
the expression expr1 is evaluated first. If it is non-zero (true), then the expression expr2 is evaluated, and that is the value of the conditional expression. Otherwise expr3 is evaluated, and that is the value. Only one of expr2 and expr3 is evaluated.
    Help
Re: Visual C++
Hey "Help" you need to study a little more, please get a good C book.
Re: Visual C++
Hi....
Now i already understand this putchar(c & Mask ? '1' : '0'); conditional expression, Thanks.....
Can you let me know what the CH carry "void Display_Byte(const unsigned char CH)", izit CH one-shot carry 1byte= 8bits...??
Display_Byte((unsigned char)(y>>8 )); , how the function work... why Display_Byte( (??)(??) ); ??
#include <stdio.h>
int main()
return 0;
for(i=1; i<=8; i++)
c<<=1;
putchar('\n');
Thanks....
Visual C++
The example does several unnecessary things. It is silly to pass argument CH as a const (that means it cannot be changed), and then copy it into a changeable variable.
I think this is clearer. Please note that I am using C. I don't know C++.
#include <stdio.h>
void Display_Byte(unsigned char c)
  unsigned char mask;
  for (mask=0x80; mask; mask >>= 1)     /* 0x80, 0x40, 0x20, ... 0x01 */
    putchar(c & mask ? '1' : '0');
  putchar('\n');
int main(void)
  unsigned int y = 0x0A0B;
  printf("Display MS byte of unsigned int y  ");
  Display_Byte(y >> 8);
  printf("Display LS byte of unsigned int y  ");
  Display_Byte(y);
  return 0;
    Help
Re: Visual C++
#include <stdio.h>
  unsigned char mask;
  putchar('\n');
int main(void)
  Display_Byte(y);
  return 0;
Hai....
The for loop result can be like that izit ....
Re: Visual C++
Hai...
condition ? exp1 : exp2
means
if condition == 1 (true) execute expr1
else execute expr2
condition here is "c&Mask"
expr1 is "putchar('1');
expr2 is putchar('0');
yes it dose so
i was mistaken plz use
if((c&Mask)==0x80)putchar('1');
else if ((c&Mask)==00x00)putchar('0');
[/b]
Re: Visual C++
shafee001 said:
Hai...
means
else execute expr2
yes it dose so
[/b]
Hai....
The program still not work....., now i using Microsoft Visual C++ izit any problem for this program..??
#include <stdio.h>
int main()
	printf("%-35s","x = ");
	Display_Byte(x);
	Display_Byte((unsigned char)(y>>8));
	return 0;
	for(i=1; i<=8; i++)
//		putchar(c & Mask ? '1' : '0');
		c<<=1; //shift c by ony bit to left in order to print next bit
	putchar('\n');
Re: Visual C++
When you posted Output.JPG, were you asking a question? What does "izit" mean?
Display_byte(x);
You never defined x. I think you meant y
00x00 is wrong, use 0x00
Suggestion: Enable all of your compiler's warnings and error messages. The messages will help you learn the language.
Re: Visual C++
Display_byte(x);
Thanks for your suggestion.....,
The program that you show me is it (izit) the output result that i show you in .jpg file...
#include <stdio.h>
  unsigned char mask;
  putchar('\n');
int main(void)
  Display_Byte(y);
  return 0;
Thank You....
