nikhillife11
Member level 2
Hello All,
I need a help with the attached circuit below. Here I know the reason for using a OP-AMP and IC AD694.
OP-AMP is used for current to voltage conversion whereas AD654 is used for voltage to frequency conversion. My problem is with the area in that RED box. Why are so my components used and how does it work. I see a diode which i assume is for reverse blocking. But I can see a zener too. Whether it is used to maintain a voltage of -2.5V is what I want to know. Can anyone explain me the logic behind that circuit in RED BOX.
Thanks and Regards
Nikhil :-D
Thanks and Regards
Nikhil :-D
BMP image replaced with GIF format which can be viewed in the browser and is smaller in size [alexan_e]
