explain to me how you select the time for a tran simulation
bouchy
Full Member level 1
USA
OP AMP Tran simulation
Hi All,
can someone pls explain to me base on what you select the time for a tran simulation.
Best regards,
Bouchy
Re: OP AMP Tran simulation
for test the settling time u have to use tran simulation, input will be step function and the output will be same bet u have to see the time of settling the outbut with the load needed
regards
    bouchy
Based on what circuit you have design.
