hbaocr
Full Member level 4
arm interrupt code
hello , all friend
Plz , explain this code below , I don't know how it work. If more than two FIQ request , how can it work, and how can CPU core recognize which interrupt source is responding.
look on my code at row painted red color ,
can me declare more than two row like this
ex:
void FIQ_Handler (void) __fiq;
void ADC_handler(void)__fiq;
And If I can do it,how can CPU recognize which FIQ Interrupt routine respond for which interrupt source when it is responded
hello , all friend
ex:
/* Examples Program For "CP-JR ARM7 USB-LPC2148" */
/* Target MCU : Philips ARM7-LPC2148 */
/* : X-TAL : 12.00 MHz */
/* : Run Speed 60.00 MHz (With PLL) */
/* : PLL Setup = M(5),P(2) */
/* : VPB Clock = CPU Clock = 60.00 MHz */
/* Keil Editor : uVision3 V3.03a */
/* Compiler : Keil CARM V2.50a */
/* Create By : Eakachai Makarn ([url]WWW.ETT.CO.TH[/url]) */
/* Last Update : 17/May/2006 */
/* Function : Example Use UART1 Show FIQ(EINT1) */
// Print Message to UART1 (9600,N,8,1)
// Used GPIO0.14 Trigger Interrupt (FIQ Vector)
// Press SW-LOAD For Trigger External Interrup-1
#include "LPC214x.H" // LPC2148 MPU Register
#include <stdio.h> // For Used Function printf
/* pototype section */
void init_serial0 (void); // Initil UART-0
int putchar (int ch); // Put Char to UART-0
int getchar (void); // Get Char From Uart-0
[color=red]void FIQ_Handler (void) __fiq; [/color] // EINT1(FIQ) Interrupt Service
int main(void)
init_serial0(); // Initilial UART0 = 9600,N,8,1
// Initial External Interrupt-1(GPIO0.14)
EXTMODE |= 0x02; // Select External Interrupt-1 = Edge Select Trigger
EXTPOLAR |= 0x02; // Select External Interrupt-1 = Rising Edge Trigger
PINSEL0 |= 0x20000000; // Set GPIO0.14 = EXTINT1 Interrupt
EXTINT = 0x00000002; // Clear External Interrupt1 Flag
// Initial Interrupt Vector
VICIntSelect = 0x00008000; // Select Interrupt-15 (External Interrupt1)
VICIntEnable = 0x00008000; // Enable Interrupt-15 (External Interrupt1)
printf("CP-JRARM7 USB-LPC2148...Example FIQ Interrupt\n");// Call Printf Function
printf("Interrupt-1 Rising Edge Trig By GPIO0.14\n"); // Call Printf Function
printf("Press Switch-LOAD For Trigger Interrupt-1\n\n"); // Call Printf Function
printf("Hello From......Main Function\n"); // Call Printf Function
// Loop Here Wait Interrupt
while(1);
/* Initial UART0 = 9600,N,8,1 */
/* VPB(pclk) = 60.00 MHz */
PINSEL0 &= 0xFFFFFFF0; // Reset P0.0,P0.1 Pin Config
PINSEL0 |= 0x00000001; // Select P0.0 = TxD(UART0)
PINSEL0 |= 0x00000004; // Select P0.1 = RxD(UART0)
U0LCR &= 0xFC; // Reset Word Select(1:0)
U0LCR |= 0x03; // Data Bit = 8 Bit
U0LCR &= 0xFB; // Stop Bit = 1 Bit
U0LCR &= 0xF7; // Parity = Disable
U0LCR &= 0xBF; // Disable Break Control
U0LCR |= 0x80; // Enable Programming of Divisor Latches
// U0DLM:U0DLL = 60.00 MHz / [16 x Baud]
// = 60.00 MHz / [16 x 9600]
// = 390.6 = 391 = 0187H
U0DLM = 0x01; // Program Divisor Latch(391) for 9600 Baud
U0DLL = 0x87;
U0LCR &= 0x7F; // Disable Programming of Divisor Latches
U0FCR |= 0x01; // FIF0 Enable
U0FCR |= 0x02; // RX FIFO Reset
U0FCR |= 0x04; // TX FIFO Reset
U0FCR &= 0x3F;
/* Write Character To UART0 */
if (ch == '\n')
while (!(U0LSR & 0x20)); // Wait TXD Buffer Empty
U0THR = 0x0D; // Write CR
return (U0THR = ch); // Write Character
/* Read Character From UART0 */
int getchar (void)
while (!(U0LSR & 0x01)); // Wait RXD Receive Data Ready
return (U0RBR); // Get Receice Data & Return
/* External Interrupt-1 Service */
printf("Hello From......External Interrupt-1\n"); // Call Printf Function
