Explain the Charge Sharing problem while sampling data from a Bus
gafsos
Full Member level 3
Full Member level 3
North Africa
What is Charge Sharing? Explain the Charge Sharing problem while sampling data from a Bus
TNX
charge sharing in bus
Say that the bus carries a single bit a certain value, to read this value, you're going to connect the input of another circuit to the bus via a switch.
Let's assume that the value on the bus is one and has a known capacitance associated with it. And also assume that your input circuit has a known parasitic cap at its output and its initially discharged.
The instance you're going to connect the two caps together, charge from the bus will go to the input parasitic cap, until both caps have the same potential. If you apply the law of charge conservation, you can predict how much drop to expect on the data bus.
Re: Charge sharing
Would you please explain it with an example, I am still confused about this concept, there are so many "input"s and "output"s in your explanation above.
Charge sharing
Well, the bus reading isn't the best example.
but in general, the problem happens when a capacitor is holding an output value is connected to another (usually parasitic) capacitor, the voltage stored on the main cap is now shared between the two, which leads to changing the value of the logic.
Here is one explanation that I found, it should be good enough to explain the concept.
h**p://www.princeton.edu/~wolf/modern-vlsi/Overheads/CHAP4-5/sld006.htm
Re: Charge sharing
due to diff voltages on capacitor of diff size when connected to the same bus for short period of time a prob is come that is know charge sharing
Re: Charge sharing
"Charge sharing"
Can you explain your question more exactly?
Regards,
SAZ
Re: Charge sharing
i didnt get u on charge sharing in a bus......plz elaborate on it..........
Re: Charge sharing
In Razavi's book,figure 12.19,12.22
there are two examples about charge injection and clock feedthrough.
Are they the charge sharing ?
Charge sharing
If it's digital bus, there are pull-up resistor to the supply. so the charge sharing is not a problem.
