Explain the below assembly program for pic
rangerskm
Full Member level 4
Full Member level 4
    #include"p16f73.inc"
    org 0x00
    bsf status,rp0
    movlw 0xff
    movwf trisa
    clrf trisb
l1: Bcf status,rp0
    movlw 0x05
    movwf adcon0
    btfsc adcon0,2
    goto $-1
    movf adres,0
    movwf portb
    goto l1
    end
this may be an adc program explain the program with the help of the adc sfrs
this may be an adc program explain the program with the help of the adc sfrs[/QUOTE]
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
    org 0x00
    bsf status,rp0          //for selecting
                            //RAM addresses 80h-ffh by default
    movlw 0xff              //for selecting
    movwf trisa             //port A an input port
    clrf trisb              //making port B an output port
l1: Bcf status,rp0          //for selecting
                            //RAM addresses 00h-7fh by default
    movlw 0x05              //Turning ON the ADC
                            //however i think 0x01 could do the job too.
                            //here you are assigning 1 to the GO bit in the
    movwf ADCON0            //ADCON0 which is not necessary
    btfsc adcon0,2          //Checking the status of DONE bit in ADCON0 (0 means ADC is
                            //has completed the conversion operation)
    goto $-1                // this should be l1. this will keep the control to the upper block
                            // of code until conversion is complete
    movf adres,0            // Move the contents of ADRES (converted data) register to
                            // WREG (workign register)
    movwf portb             //Send the converted data from WREG to PORTB
    goto l1                 // Keep looping back to the upper block of code for
                            // next analog signal to be converted
    end
