Explain me this syntax from C programming
tok47
Full Member level 1
Kuala Lumpur, MALAYSIA
getname c programming
Dear ALL,
Can some1 explain for me, the below syntex from C PROGRAMMING?
THANKS alots
char vbuff [600][32]
int vnum_mods =0
while (fgets(vbuff,200,vmodin)) {
if (isvmod()) {
getname(0,0);
vnum_mods++;
fclose(vmodin);
Re: c programming
You need to post the implementation of
getname(int,int)
Re: c programming
whatz the nature pf isvmod() and getname() functions?
are there standard functions like that?
Re: c programming
Please gimme the list of header files used.
Re: c programming
Dear Fren,
I got the answer already. I think I wont post the details for isvmod() and getname(int,int) here coz is a quite long program. ANyway, thanks for reply.
Another question : Can I use 'strcmp' to compare the details of 2 files?
Re: c programming
hi,
you cannot do it directly.ypu have to buffer the contents of the files and and then you can use strcmp.Needless to say if a file is too large this approach would not be very fruitful.
pimr
Re: c programming
getname function detail is required ...
Added after 52 seconds:
for helping you getname function detail is required ...
