Explain me the deep sub-micron technology
p_shinde
Full Member level 5
Full Member level 5
tokyo
Deep sub-micron tech
hi,
how can one explain deep sub-micron technology?
thanks in advance,
Prasad
Re: Deep sub-micron tech
hi,
from designer's perspective, deep sub-tech means faster, more leakage power, and more SI issue.
Deep submicron technology means,using transitoros of smaller size with faster switching rates. As we know from Moore's law the size of transistors are doubled by every year in a system,the technology has to fit those inc in transistors in small area with better performance and low-power.
Submircon Name is due to 0.35um>0.25um>0.18um>0.13um as reduced in sizes of micron level.
Several issues in Deep submicron technology are:
Challenges for Low-Power Design
Better Signal Integrity or Signal quality
High-Desity and Design Complexity
Packing such complex chips and Testing
Also Cost efffective approach to reduce Higher Design NRE
Rgds,
ALI
Is this deep submicron technology related to frequency of operaion of the chip? If so, can you please explain the concept......
Micron tehcnology ==> 1um, 2um, 3um, etc
sub-micron techology ==> 0.8um, 0.6um, 0.35um 0.25um etc
deep sub-micro technology ==> 0.18um, 0.13um
nanotechnoogy ==> 90nm, 65nm etc
Basically, use the words "sub" and "deep" as in the English defination of the words.
Regards,
Eng Han
    minhchau
Of course deep-submicron even nano technology means high-density integration.
In my opion the biggest problem we should face in nano design are leakage, temperature susecibility, signal/power intergrity and device parameter variability.
