firsttimedesigning
Full Member level 1
![Full Member level 1](/styles/images/ranks/elevel1.gif)
recently i am studying CMFB. i have attached file that has a circuit uses CMFB.
my question is that when Id3 and Id4 increase, why does that ouptut CM get lowered?
I think it's because that there is a set amount of current flowing into R1 and R2 from PMOS transistors. There is also a set amount of current flowing out of R1 and R2, namely Id3 + Id4. Since Id3 + Id4 increase, there is more current flowing out of R1 and R2. Therefore, the output CM level decreases. I am not sure if I am right..
One thing that i should add is Ve is the difference between Vout,cm and Vref.
Vref is connected to the negative input of the amplifier.
I also would like to know why does the feedback circuit forces Vout,cm to be equal to Vref?
