Experience Advanced Performance with Forlinx TI Sitara Cortex-A53 AM625x System on Module
Forlinx
Banned
Member level 2
The FET6254-C is a cost-efficient and advanced performance System on Module (SoM) based on TI Sitara. AM62x series industrial grade SoCs powered by ARM Cortex-A53 cores with speeds up to 1.4GHz. It's integrated with a wide array of interfaces such as dual Gigabit Ethernet ports enabled with TSN, USB 2.0, LVDS, RGB parallel, UART, OSPI, CAN-FD, Camera and Audio.
r/SingleBoardComputer - Experience Advanced Performance with Forlinx TI Sitara Cortex-A53 AM625x System on Module
The SoM is designed with four ultra-thin connectors on its back for mating with carrier board and the combined height is only 2mm, which is convenient for plug operations and maintenance. All functional pins are available on a compact layout, which is much more convenient for users to do development work and all components on it are industrial grade with operating temperature ranges from -40℃ to +85℃.
Features of AM6254 SoM
• Dual display support
• 3D Graphics Processing Unit
• High-Speed Interfaces(Integrated Ethernet switch supporting)
• 1× General-Purpose Memory Controller (GPMC)
• Functional Safety
• 16-nm technology
FET6254-C System on Module offers unmatched performance, enhanced security, and a wide array of features to take your projects to new heights. Experience the future of technology and unlock limitless possibilities with the FET6254-C SoM.
For additional information, visit the FET6254-C System on Module
